westindian
Oct 22, 2021Aspirant
Orbi CBR40 - Spectrum 400Mbps but only getting 170Mbps max
Just upgraded from 100Mbps to 400 Mbps on Spectrum, but even after Spectrum troubleshooting it still shows only 170Mbps on the Orbi speed test. Spectrum says they show they are pushing 400+Mbps to my...
westindian
Yup, pwered off for a minute and then tested using the Orbi App speed test. My laptop does not have a hardwired connection port unfortunately, but checked online using Spectrum spped test (ookla) on their website as well. Still less than 200 Mbps.
Oct 22, 2021Guru - Experienced User
You might try a factory reset on the CBR and setup from scratch. Don't enable Armor, Circle or Traffic Meter. Just test as soon as the CBR is updated.
We've seen problems in recent history with Orbi app and on board speed test app not reporting correct speed results while a wired PC using a external app does report correctly.
- westindianOct 22, 2021Aspirant
Thanks for the advice! Appreciate it! I do have Circle enabled, I'll disable and reboot again and see what happens!
- FURRYe38Oct 23, 2021Guru - Experienced User
OK, let us know how it does...Seen issues with Circle in the past as well. :smileyfrustrated:
