ellaberq
Aug 01, 2021Follower
Orbi CBR40 and RBK22 Can these work together?
Hello. My internet service is not great. We were advised by the tech guy at Costco to purchas the Orbi mini RBK22 (has router and satellite) and then to buy from amazon/online the Orbi CBR40. So I ...
Aug 06, 2021Guru - Experienced User
The CBR40 and RBR20 will not work together as a wireless MESH system. You can connect the RBR20 in AP mode however it would be a separate wifi SSID system appart from the CBR. You can however configure the CBR40 for modem mode only, then connect the RBK22 system to it and this would be your main host router wifi system while the CBR is just the modem only.
ellaberq wrote:
Hello.
My internet service is not great. We were advised by the tech guy at Costco to purchas the Orbi mini RBK22 (has router and satellite) and then to buy from amazon/online the Orbi CBR40. So I did that. Now I am trying to figure out if they can work together as it seems the CBR40 is a Modem/Router. Will I be able to use the mini router still?
Thanks for any help.
