ractech
Apr 06, 2022Follower
Orbi CBR40 cable modem/router on Specrum
A couple weeks ago Spectrum sent me a new modem and said the old Spectrum modem (which I don't have) would be obsolete with their new 400Mb service. I called and asked if I would be able to use my Or...
Apr 06, 2022Guru - Experienced User
Wow, love how ISPs just can do that. Say one thing then all of a sudden with out notice, change.
Thought the CBR40 is only DOCSIS 3.0 so possible that the ISP is moving this out of support for them since D 3.1 has been out for while now. Its up to the ISP to decide what they want to support and what they don't. You may need to upgrade to something 3.1 at some point. Might ask the ISP if they can give you any information on when D 3.0 modems will no longer be supported so you might have a time frame to check into something newer.
