zane310
Nov 10, 2018Initiate
Orbi CBR40 cannot connect Security System
Hello
After setting up my Orbi and satellite I connected all my devices, wireless and hard wired the problem I have is I have a Honeywell Tuxedo Touch security system that will not connect to it. ...
tcm004
Nov 14, 2018Aspirant
abolve post
- zane310Nov 15, 2018InitiateI found a work around , just make you a guess account with a password and your Honeywell will see it, put in you password and it will connect it fixed mine
- tcm004Nov 15, 2018AspirantThanks, I will try it out tonight. I really like the increased speed but I need to control 8 lights doorlooks , an thermostat.
- tcm004Nov 16, 2018AspirantThanks it Working. I’m not sure if it was the update dad got it working or buy me switching to the guest account Any boot it’l works thanks
