DWo
Sep 27, 2020Follower
Orbi CBR40 downstream light blinking
My Orbi downstream light is flashing continually and I'm getting 15Mbps to 35Mbps, sometimes as low as 9Mbps. Sometimes my internet just drops out. My provider plan is up to 300Mbps, but I usually ge...
Thco213
Oct 21, 2020Aspirant
Did you ever get this resolved? I am having the same issues and need some help! Any suggestions a would be great. Thanks!
Oct 22, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
