gabegarcia
Mar 28, 2021Aspirant
Orbi CBR40 Getting DoS attack: snmpQueryDrop
Hello, Is Obri blocking these DDoS attacks? I'm seeing about 10 attacks per day in the logs. I've checked their IP's and they are not the false positive scenarios like Facebook, Amazon, or Dr...
- Mar 29, 2021
gabegarcia wrote:Is Obri blocking these DDoS attacks?
I'm seeing about 10 attacks per day in the logs. I've checked their IP's and they are not the false positive scenarios like Facebook, Amazon, or Dropbox.
Should I be concerned?
Yes, Orbi's firewall does not accept connection attempts from the internet until the user deliberately sets up either port forwarding, Remote Administration, or OpenVPN. These log entries are the result of firewall logic which collects connection requests and attempts to assign them to categories. I monitor two Orbi systems and they both regularly log about 30 of these "attacks" every day. (Yes, every day.) I have seen comments that Netgear's logic is flowed and logs things as "attacks" that are not.
I do not recall seeing any "snmp" events in my log files.
Be Concerned? I think not. If you would rather not see the entries in the log file, there is an option to stop logging them.
CrimpOn
Mar 29, 2021Guru - Experienced User
- gabegarciaMar 29, 2021Aspirant
- FURRYe38Mar 30, 2021Guru - Experienced User
Be sure to visit and post about this in the Orbi with cable modem forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
