ylebron
Jun 06, 2019Aspirant
Orbi CBR40 Interrupted connections all day long
I have the orbi CBR40 and satellite at home and it has stopped working correctly in the past few months. The firmware is up to date (2.3.0.10) and I have not made any changes to it. My Internet provid...
Jun 18, 2019Guru - Experienced User
Any status on this?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
ylebron wrote:
I have the orbi CBR40 and satellite at home and it has stopped working correctly in the past few months. The firmware is up to date (2.3.0.10) and I have not made any changes to it. My Internet provider (Comcast-Xfinity) has done all they can: changed cables, sent a technician, tested remotely etc and it is all working from their end. The only thing they have mentioned is that they are receiving overheat signals coming from my Modem/Router. I really need this issue fixed since I work from home and this is getting a little frustrating.
My orbi app says everything is connected and no flashing magenta light is coming from the Orbi but I have no internet on my devices. HELP!
ylebron
Jun 18, 2019Aspirant
My house is around 2900 sqft.
Distance from router and satellite is around 25 ft.
I have the default channels, have tried the suggested in the post and nothing works either.
I have three or fourwi-fi connections close to my house.
I also tried resetting to factory settings, which worked for a few days and now it is back to being interrupted.
- FURRYe38Jun 18, 2019Guru - Experienced User
Can you try turning OFF the RBS temporarily and see if the interruptions continue or not.
What channesl are your wifi neighbors using?
25 feet is a bit too close between the CBR and RBS. 30 feet or more is needed.
