ylebron
Jun 06, 2019Aspirant
Orbi CBR40 Interrupted connections all day long
I have the orbi CBR40 and satellite at home and it has stopped working correctly in the past few months. The firmware is up to date (2.3.0.10) and I have not made any changes to it. My Internet provid...
ylebron
Jun 18, 2019Aspirant
My house is around 2900 sqft.
Distance from router and satellite is around 25 ft.
I have the default channels, have tried the suggested in the post and nothing works either.
I have three or fourwi-fi connections close to my house.
I also tried resetting to factory settings, which worked for a few days and now it is back to being interrupted.
Jun 18, 2019Guru - Experienced User
Can you try turning OFF the RBS temporarily and see if the interruptions continue or not.
What channesl are your wifi neighbors using?
25 feet is a bit too close between the CBR and RBS. 30 feet or more is needed.
