JDM1967
Nov 27, 2020Follower
Orbi CBR40 Manual reset with not restore "password" back to factory settings
Bought second hand an Orbi CBR40 Cable Modem which I was able to successfully connect to the cable service (comcast) as well as other devices through out the house. That's the great news! I how...
- Nov 27, 2020
Pressing the reset button for 15 seconds then release is all thats needed. Try this again with the ISP Coax cable disconnected from the CBR40. Wire connect a PC or laptop to the back of the CBR40. Use a web browser pointed at 192.168.0.1 or try orbilogin.com.
Nov 27, 2020Guru - Experienced User
