steveberry10
May 16, 2020Tutor
Orbi CBR40 password reset endless loop
I'm trying to reset the admin password on my Orbi cable modem/router and I'm stuck in the old endless loop: answer questions, choose new password, answer questions again, password is invalid, rinse &...
Oct 03, 2020Guru - Experienced User
Factory reset the CBR40 and setup from scratch. Be sure to walk thru the setup wizard and write down all important information for safe keeping.
BaumgartN wrote:Did you get a splve for this. I'm havinng the same issue. Tried on multiple browsers and devices.
d700
Feb 03, 2021Apprentice
Same is happening on my Orbi RBR750.
Joke is on me, I swore off Netgear after buggy software and aggravation on the last 2 NightHawks I bought. My son recommended this new company, Orbi.
It worked great when I set it up the first time but I almost took it back when I learned it was a Netgear company,
Once I started having problems like this I wish I would have.
I am about to do my 2nd factory reset in 6 months.
I absolutely hate Netgear and will not recommend either Netgear or Orbi to anyone. Not to mention these forums are a joke, blind leading the blind, noone from Netgear monitors, offers solutions.
Netgear you are just horrible
