Jd7744
Jul 15, 2019Aspirant
ORBI CBR40 problem with WD Cloud NAS
I have 2 ORBI based systems. NO1 is RBR50 with 4 satellites using FIOS router DMZ so the RBR does all router IP distribution, wireless and wired. Works great. NO2, in a different house, is CBR40 as m...
Jul 17, 2019Guru - Experienced User
Shouldn't be any differences. The CBK is just a modem built in with Orbi HW.
Might try setting NAT Filter from Secure to OPEN and test.
Try configuring some Port Forwarding to see.
Set the CBR40 to modem only mode and connect a different router to the back of the CBR40 and see if the problem continues...
