LawJolla
Jun 08, 2020Aspirant
ORBI CBR40 slow device speeds when not shown as connected device
Orbi CBR40, v2.3.5.12__1.0.8 Hello! When a particular computer connects to the Orbi, it shows up as a connected device with proper speeds (320mbps). But soon after, the computer is lost as a...
Jun 09, 2020Guru - Experienced User
Do you have a RBS connected as well?
Is the PC wired or wireless connected to the CBR?
What is the mfr and model# of the wired and wireless adapters in this PC?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
