sudheerchinta
Jun 21, 2020Tutor
orbi CBR40 with at&t gateway
I am trying to connect my orbi CBR40 router/modem to AT&T gateway modem. I want to use CBR 40 as a router as I have 2 satellites that can extend the wifi signals throughout the house. I used this for...
- Jun 22, 2020
You might be able to follow the guide to make it work as a simple access point. It might work. the guide is written for a c6300 but might work with the CBR40.
otherwise you'd want to buy a standard orbi router to control it and not the modem/router combo device.
sudheerchinta
Jun 21, 2020Tutor
So, I cannot use this at all in any way with At&t?
Jun 22, 2020Guru - Experienced User
- sudheerchintaJun 22, 2020TutorThank you. I will try that today.
- FURRYe38Jun 25, 2020Guru - Experienced User
- FURRYe38Jun 26, 2020Guru - Experienced User
I can confirm that the CBR40 can be used as a wired AP if you disable DHCP and set up a new IP address for the CBR40. Then connect the CBR40 to a up stream router using any LAN port in back. Although if one uses this configuration on the CBR40, the top ring LED will always be on PINK and the front led modem downlink will always blink. One can put a post it note over the front of the LED to make it dim.
- sudheerchintaJun 29, 2020Tutor
Yes, it worked like a charm.
