sudheerchinta
Jun 21, 2020Tutor
orbi CBR40 with at&t gateway
I am trying to connect my orbi CBR40 router/modem to AT&T gateway modem. I want to use CBR 40 as a router as I have 2 satellites that can extend the wifi signals throughout the house. I used this for...
- Jun 22, 2020
You might be able to follow the guide to make it work as a simple access point. It might work. the guide is written for a c6300 but might work with the CBR40.
otherwise you'd want to buy a standard orbi router to control it and not the modem/router combo device.
sudheerchinta
Jun 29, 2020Tutor
Yes, it worked like a charm.
Jun 29, 2020Guru - Experienced User
Glad to hear it worked for you and you were able to keep using the system without having to invest extra $
