m14mike
Feb 26, 2020Aspirant
Orbi cbr40
I have the Orbi CBR40 with no mesh adapters. I am looking for the best POE WAP to add to this system. Any suggestions? Thanks!
- Feb 28, 2020
This is not true.
From this spec sheet, any GS10#PE are PoE supporting. The GS10#E series is not PoE supporting.
If you need PoE support in your switches, you'll need the PE series.
Be sure to post about this in the switch forum for more information if you need:
https://community.netgear.com/t5/Managed-Switches/bd-p/business-managed-switches
Good Luck.
Feb 26, 2020Guru - Experienced User
PoE is not supported on Orbi.
Only extenders or AP that work with Orbi is RBS20s for this CBR40.
m14mike wrote:I have the Orbi CBR40 with no mesh adapters. I am looking for the best POE WAP to add to this system.
Any suggestions?
Thanks!
- m14mikeFeb 28, 2020Aspirant
Let me rephrase that....
My Orbi is connected to two Netgear Prosafe GS108E switches. My research shows that these switches can do POE/WAP.
Is this not true?
- FURRYe38Feb 28, 2020Guru - Experienced User
This is not true.
Good Luck.
Exactly what I was looking for, thank you!
