EastonDJones
Apr 26, 2023Aspirant
Orbi CBR40
I cannot add security method or password to my guest wifi. It says "Configuration Error: Orbi could not apply your new settings. Check your WiFi connection and try again" Then the options to click...
- Apr 27, 2023
I finally got it!
Thank you for replying.
I was trying on the app. Factory reset it, turned off and on, and everything.
I was trying on accounts.netgear.com and it said I had to do everything on the app.
Finally, I fould the different website orbilogin.com and then realized I could do it online. Probably spent three hours trying to give it a password the last 2 days. The app must be glitching for me.
EastonDJones
Apr 27, 2023Aspirant
I finally got it!
Apr 27, 2023Guru - Experienced User
Glad you got if fixed!
I'd make a backup and then mark this as solved so others aren't still trying to fix this 🙂
- EastonDJonesApr 27, 2023Aspirant
Thank you for your help!
