jbrown316's avatar
jbrown316
Apprentice
Aug 11, 2020
Orbi certificate issues on WiFi only
Hi all, just this morning I am having trouble using WiFi on my RBR50.  Wired devices seem to be working ok.  When I navigate to a website (i.e. Google) over WiFI, I am getting certificate/privacy err...
  • jbrown316's avatar
    jbrown316
    Aug 11, 2020
    I may have figured this out after acquiring a few more gray hairs.  I went into the advanced settings, security, access control from the Orbi UI and disabled, then re-enabled my laptop access.  It seems that doing that may have freed up all of the devices that were getting blocked.
    That is a super buggy and kludgy fix for a router this expensive.  Hopefully it will help someone else.
