jbrown316
Aug 11, 2020Apprentice
Orbi certificate issues on WiFi only
Hi all, just this morning I am having trouble using WiFi on my RBR50. Wired devices seem to be working ok. When I navigate to a website (i.e. Google) over WiFI, I am getting certificate/privacy err...
- Aug 11, 2020
I may have figured this out after acquiring a few more gray hairs. I went into the advanced settings, security, access control from the Orbi UI and disabled, then re-enabled my laptop access. It seems that doing that may have freed up all of the devices that were getting blocked.
That is a super buggy and kludgy fix for a router this expensive. Hopefully it will help someone else.
Justadude123
Aug 11, 2020Aspirant
Looks like your not on the latest version. There aren't any release notes yet so maybe wait for that or try updating through orbi app.
jbrown316
What is the latest version? I checked the firmware update through the Orbi UI and it says that no new firmware is available...
- jbrown316Aug 11, 2020Apprentice
- FURRYe38Aug 11, 2020Guru - Experienced User
Thanks for letting us know.
Please mark your thread as solved so others will know,
- jasonreamsAug 02, 2022Tutor
Same issue and same resolution on 8/2/2022
