jbrown316
Aug 11, 2020Apprentice
Orbi certificate issues on WiFi only
Hi all, just this morning I am having trouble using WiFi on my RBR50. Wired devices seem to be working ok. When I navigate to a website (i.e. Google) over WiFI, I am getting certificate/privacy err...
- Aug 11, 2020
I may have figured this out after acquiring a few more gray hairs. I went into the advanced settings, security, access control from the Orbi UI and disabled, then re-enabled my laptop access. It seems that doing that may have freed up all of the devices that were getting blocked.
That is a super buggy and kludgy fix for a router this expensive. Hopefully it will help someone else.
jbrown316
What is the latest version? I checked the firmware update through the Orbi UI and it says that no new firmware is available...
jbrown316
- FURRYe38Aug 11, 2020Guru - Experienced User
Thanks for letting us know.
Please mark your thread as solved so others will know,
- jasonreamsAug 02, 2022Tutor
Same issue and same resolution on 8/2/2022
