wvwalt
Dec 13, 2017Tutor
ORBI Change satellite password
Orbi Satellite - can login to the satellites with "admin/password", even after I change the password for the Orbi router. Question: How can I change the password for the Orbi Satellites? Alre...
wvwalt
Dec 13, 2017Tutor
Allow me to clarify. Router, at 192.168.1.1 has password of blahblah.
satellite is on network with an IP of 192.168.1.180. I can open a web browser, and enter 192.168.1.180 in the address bar and get a login prompt for the satellite. The login is NOT admin/blahblah. The login to the satellite is still the default of admin/password.
i would like to change the login of the satellite to be the same as the login to the router, which is admin/blahblah. I see no option to do this. Is it possible?
DarrenM
Dec 15, 2017Sr. NETGEAR Moderator
I will look into this and see if I can get a answer.
DarrenM
