wvwalt
Dec 13, 2017Tutor
ORBI Change satellite password
Orbi Satellite - can login to the satellites with "admin/password", even after I change the password for the Orbi router. Question: How can I change the password for the Orbi Satellites? Alre...
wvwalt
Dec 15, 2017Tutor
Thank you. I understand what you are saying, and I agree that is the way it should operate. My setup is not doing that, however. I have re-synced my two satellites with my router, and they both show as connected to the router when I view the router config.
Password for the router is blahblah, which I changed from the default. The login on the two satellites remains admin/password, however, even after syncing. Connections to the satellites is good; I moved them closer to the router as a test. No change.
jasc76
Jan 25, 2018Initiate
Have the same issue
