ArthurP
Jun 12, 2021Aspirant
Orbi choosing wireless backhaul when wired is available?
I have the Orbi router and two satellites running wired into a TP link switch. But the satellites connect to the router over the wireless backhaul. The satellites use the wired connection to connec...
- Jun 12, 2021
ArthurP wrote:I have the Orbi router and two satellites running wired into a TP link switch. But the satellites connect to the router over the wireless backhaul. The satellites use the wired connection to connect to each other but not the router! The third satellite is only wireless, as it should be.
My intuition is that the wired connection would always be preferred because it is more reliable, higher bandwidth and faster(?). Is something wrong here or is this normal behavior?
Unfortunately, Netgearis forum software package does not allow others to view images that are placed "in-line" using the Photos icon in the menu bar until the images are approved by a forum moderator. There are not many moderators, so this can take hours (or days). Images "attached" using the Browse button in the lower left of the edit panel appear immediately.
- Which specific TP-Link switch is being used?
- Orbi routers expect satellites to appear on LAN ports, not on the WAN port, so it is important that the switch is connected to an Orbi LAN port ('behind' the Orbi) rather than between the Orbi and the ISP modem.
