dbriankessler
Nov 24, 2020Tutor
Orbi, Circle, and Powerline 2000 help needed
I have the Orbi RBR20 with three RBW30's attached throughout the house. We use Circle to limit the kids time on the devices. The internet connection wasn't good enough for gaming though, so I bought ...
dbriankessler
Nov 25, 2020Tutor
Thanks for the suggestion, however, it makes no difference how they are connected into the system (unless it's completely wifi), these two devices don't even show up in the list of devices on Circle. Circle uses the MAC address of the device. It's almost like the Powerline device completelt masks the visibility.
Nov 25, 2020Guru - Experienced User
I would remove the power line devices to check to see if the other devices then show up in Circle, if they do, then the issue is with the powerline devices. Someting to discuss with the Mfr of the PL devices.
dbriankessler wrote:Thanks for the suggestion, however, it makes no difference how they are connected into the system (unless it's completely wifi), these two devices don't even show up in the list of devices on Circle. Circle uses the MAC address of the device. It's almost like the Powerline device completelt masks the visibility.
- dbriankesslerNov 25, 2020TutorThe Powerline 2000 device is a Netgear product.
- FURRYe38Nov 26, 2020Guru - Experienced User
Also post about this over in the Power Line forum.
