jlcarpenter's avatar
Jul 18, 2019
Orbi Circle Connectivity
I am having trouble with the circle app when used with my Orbi router with built-in Circle. When I open the app it says cannot connect to circle. I try to reconnect with the same issue. I have restarted the app and the router with the same result.
1 Reply
  • Not to put you off, but my observation is that there are not a lot of Circle users on this forum.
    Netgear has an entire community forum dedicated to Circle: https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
    You might get a more informed response (and more quickly) by posting on that forum.
    Disclaimer: I have no need for Circle, dislike subscriptions, and thus have not ever activated Circle, not even for a test.  Maybe someone else will offer a solution?
