ACC91009
Jan 20, 2018Tutor
Orbi Circle setup loops in app
Im using IOS 11.2.2. I´ve been using my ORBI for 6 months flawlessly. Today I installed Circle, but I cannot set i up. The setup loops in the Circle app in the the "Your router is compatible"..."D...
- Jan 23, 2018
Not really. Just using the APP. However, after a couple days or looping, I tried again and suddenly, it worked. I have no clue what it was. I noticed a circle app update in my iphone the day before, probably that was it. dont know. I´ll close this now.
Tks
Soke577
Feb 22, 2018Initiate
I have the same issue. Update iOS. Rebooted the router. Continue the eternal loop setup. I need help
Only work in Android devices.
- ACC91009Mar 09, 2018Tutor
I had to factory reset my router. Tried to install Circle, and Im here AGAIN in the ethernal setup loop. Still cant find the answer to this problem. I disabled circle using the web access, and then try to do everythin again from the Circle App. But it fails with a message "oh something sent wrong, try again". And thats it. Cannot setup circle
- litgearMar 10, 2018GuideI think I had the same issues on Android with everything up to date. I think I disabled circle in the router, rebooted, reenabled it probably tried it then and probably rebooted the router one more time. It was finicky to set up the first time but I've used it a few months now with no major issue since.
- ichsuMar 31, 2018Aspirant
I have the same problem. I tried the app, I got the loop. I don't see the enable button when I tried the web approach.
