natebirr
Sep 12, 2017Follower
Orbi Compatibility
What is the limit of the range between the Orbi router and Orbi satellite? Can the router be connected to the modem wirelessly or to a wireless access point?
DarrenM
Sep 13, 2017Sr. NETGEAR Moderator
Hello natebirr
The distance relies on your environment but each unit can cover 2500 sq feet you will just have to test what is the best connection. And no you can not connect the router wirelessly to a modem.
DarrenM
