Cornish27
Jan 29, 2019Guide
Orbi compatibility
I am thinking of ditching my ASUS TR-AC68U in favour of an Orbi soution. Will an Orbi mesh set up work well with my ASUS AC68U PC network card
- Jan 29, 2019
Ok, the distance is something to keep in mind for Orib and the satellite(s)
Cornish27
Jan 29, 2019Guide
Squ ft not so huge, but it's over three floors and long! About 90 ft. Have to cover my office on top floor and entertainment at the other end on the ground floor
Jan 29, 2019Guru - Experienced User
- Cornish27Feb 02, 2019Guide
So I tried it. Mega result! Absolutely no compatibility issues with the PCE card. And the sytem has delivered twice the speed and coverage of the ASUS system it replaces.
Shock horror!! Product provides everything it says on the tin! Great system!
- Chuck_MFeb 02, 2019Mentor
Great news.... no issues in setup or config!?
- FURRYe38Feb 02, 2019Guru - Experienced User
Glad its working well for you. Enjoy the system. :smileywink:
No issues really.
It does take forever to do its thing, recognising the satellite for example. But if you have patience it's fine
Its doing a handskaking routine is all, between it and the orbi, finding best single to use.
Enjoy. :smileywink:
