Edd2nd
Mar 19, 2019Aspirant
Orbi compatibility
I have a d-link Taipan and the Netgear ex7000 extender but i would love to have a mesh system at home because of home security cameras as well as other devices the tri band seems good so i can have s...
Mar 19, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem you currently use?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
House size Find Your Orbi System:
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
Edd2nd wrote:
I have a d-link Taipan and the Netgear ex7000 extender but i would love to have a mesh system at home because of home security cameras as well as other devices the tri band seems good so i can have some coverage outside and in my shed as well but i am concerned about the compatibility of Orbi with the dlink Taipan.? Any tips and or advice would be appreciated.
Edd2nd
The square foot of house is around 2160 and the modem is a D-link TAIPAN DSL4320L and the Orbi RBK50 was my first choice but wondered if it would be compatible with the D-link TAIPAN DSL4320L. And the house is double brick as well.
