Edd2nd
Mar 19, 2019Aspirant
Orbi compatibility
I have a d-link Taipan and the Netgear ex7000 extender but i would love to have a mesh system at home because of home security cameras as well as other devices the tri band seems good so i can have s...
Mar 20, 2019Guru - Experienced User
You DSL modem has a router and wifi built in:
https://www.dlink.com.au/home-solutions/DSL-4320L-taipan-ac3200-ultra-wi-fi-modem-router
Try band as well. AC3200 while the Orbi is AC3000.
You may want to just add an extender to the modems wifi for signal coverage. You might check into D-Link DAP series extenders.
In order for the Orbi to work well, you would need to either bridge this modem and disable ALL wifi on this modem then you could use the Orbi in router mode, or just disable the wifi on this modem and use the Orbi in AP mode.
Edd2nd wrote:
The square foot of house is around 2160 and the modem is a D-link TAIPAN DSL4320L and the Orbi RBK50 was my first choice but wondered if it would be compatible with the D-link TAIPAN DSL4320L. And the house is double brick as well.
Edd2nd
Mar 21, 2019Aspirant
Thanks Furry i have taken your advice onboard and ordered the dap 1860 and give that a go as it does seem to be matched with me taipan. I was impressed with the 7700 ext untill the origin modem **bleep** the tin and we had a few power blacouts and it all went pear shaped from then. Thanks again for your help. Regards Edd
- FURRYe38Mar 21, 2019Guru - Experienced User
Enjoy. :smileywink:
