OzzzieMike
Dec 09, 2018Apprentice
Orbi-Compatible Smart Plugs?
I see that all the smart plugs on the market are limited to the 2.4GHz WiFi band. Are there any recommendations for smart plugs that set up easily with the Orbi system, and don't require any "workaro...
JoeCymru
Dec 09, 2018Virtuoso
I am using TP Link Kasa plugs. Also lights and switches. All set up quickly and immediately. I use Google Honme, and that works fine with Orbi and the Kasa devices. Alexa should be fine also.
- OzzzieMikeDec 09, 2018Apprentice
Thanks Joe!
I'll get one of those plugs, then.
My concern, as stated previously, is that the Orbi system is set up such that the 2.4GHz and 5GHz bands use the same SSID, and I've been unable to connect my Whirlpool applicance because both the applicance and my iPhone must be on the same 2.4GHz network during setup. There's no means I've found of "forcing" my phone to connect to the 2.4GHz band...it always connects to the 5GHz band. And, even when I'm able to temporarily shut off the 5GHz band (and verify my phone and applicance are both connected to the 2.4GHz band) I'm not able to complete the setup on my iPhone.
Thanks again for the recommendation!
- JoeCymruDec 09, 2018Virtuoso
First, I had no problem that way for the Kasa set up even though it is the same potential 2.4GHz issue. With your appliance, the issue is one that appears often with Orbi being both networks on same SSID and setting up some finicky devices. One thing you may try is turning your 5GHz singnal down very low in Orbi while you are attempting the appliance set up. On web interface for Orbi, Advanced>Advanced Setup>Wireless Settings under 5GHz. If you are near a satellite you may want to power it down. If you are near the router take the 5GHz signal down to perhaps 25%. One other thing you may do to help you in this is download WiFi Analyzer. You can see signal strength on your phone so can get a feeling when your phone will perfer the 2.4GHz band because the 5GHz is so low at the point you are located. This will also help you determine how low to set the 5GHz output to inssure your phone is connected to 2.4GHz only.
I've tried the suggestions you posted before, but they really didn't work for me (or the applicance). The only thing I haven't tried, and just thought of, is to temporarily turn off the 5GHz band, then perform a Reset Network settings on my phone...then try to connect this appliance to the phone. (I'm thinking that maybe, when I ensured both the phone and applicance were connected to the 2.4GHz band, my phone still thinks it's on a different network than the applicance?).
Anyway...that's a subject for a different thread, not this one. I've ordered the TP Link plug recommended earlier...it should arrive Tuesday.
- ZeroAuthorityApr 08, 2019AspirantWhat model of TP Link Kasa outlet?
