OzzzieMike
Dec 09, 2018Apprentice
Orbi-Compatible Smart Plugs?
I see that all the smart plugs on the market are limited to the 2.4GHz WiFi band. Are there any recommendations for smart plugs that set up easily with the Orbi system, and don't require any "workaro...
mrscientist
Dec 10, 2018Aspirant
Hi, I've been using 20+ of the cheapo wi-fi plugs you can find on Amazon for anywhere from $5-10 without any issues. They all connect to the 2.4 and happily stay there. I also have a few D-Link plugs that work without issue as well. Good luck.
