OzzzieMike
Dec 09, 2018Apprentice
Orbi-Compatible Smart Plugs?
I see that all the smart plugs on the market are limited to the 2.4GHz WiFi band. Are there any recommendations for smart plugs that set up easily with the Orbi system, and don't require any "workaro...
JoeCymru
Dec 09, 2018Virtuoso
I am using TP Link Kasa plugs. Also lights and switches. All set up quickly and immediately. I use Google Honme, and that works fine with Orbi and the Kasa devices. Alexa should be fine also.
ZeroAuthority
Apr 08, 2019Aspirant
What model of TP Link Kasa outlet?
