jbell0912
Jun 15, 2021Aspirant
Orbi connected but no internet
I recently purchase an Orbi AX 4200 RBK 752 router. It has one satelittle. During setup I can go thru the hole process but when it gets to the end it will not check for new firmare because it is not broadcasting internet. I have tried thru the APP and thru a wired connection with m computer and cannot get internet. My modem is a verizon 4G LTE modem and I have it hooked up to a TP Link router and that works fine.. You cannot enable bridge mode so I have diabled the 5 GHZ and 2.4 GHZ wifi connections. There are no wifi connections coming from the modem. Can anyone tell me why it will not broadcast internet? Do I need to change a setting or something? I returned the first one I bought thinking it was defective but this one is doing the same. Tech support has not been much help.
1 Reply
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axPlease do not post pictures with Serial numbers or MAC addresses in public forums.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #3 first...
Thank you.
