Spiffywerks
Mar 30, 2019Guide
Orbi connected directly to FIOS ONT gets only 50% connection speed
I have an ARRIS NVG468MQ quantum gateway from Frontier FIOS with 150/150 Mbps service using the ethernet port from the ONT.
I have tried the following setups and found that if I plug the ORBI d...
- Apr 07, 2019Turns out it was a cable issue. The cable running from my ONT up to my attic was the problem. I ended up just putting the router in the garage near the ONT and the speed is now 150/150 everywhere in the house. Very happy with it now!
ekhalil
Mar 31, 2019Master
- Does your Internet connection require any authentication?
- Try using the MAC address of the Ariss router in Orbi internet settings, you can find this seetting in the web GUI under >> ADVANCED >> Setup >> Internet Settings >> Router MAC Address
Spiffywerks
Mar 31, 2019Guide
The Internet connection does not require authentication. That's why the connection works when just simply taking the cable running from the ONT and plugging it into a computer. Doing this I get the full 150/150 bandwidth.
I set the MAC address to the one from the ARRIS, for 5 minutes the connection speed shot up to 150/120, but a little while later, dropped back to 80/100.
I think the next thing I'll try is putting the router right next to the ONT and check with a different cable. Currently, there is about a 70 ft CAT5-e cable running between my garage and the Router.
