Spiffywerks
Mar 30, 2019Guide
Orbi connected directly to FIOS ONT gets only 50% connection speed
I have an ARRIS NVG468MQ quantum gateway from Frontier FIOS with 150/150 Mbps service using the ethernet port from the ONT.
I have tried the following setups and found that if I plug the ORBI d...
- Apr 07, 2019Turns out it was a cable issue. The cable running from my ONT up to my attic was the problem. I ended up just putting the router in the garage near the ONT and the speed is now 150/150 everywhere in the house. Very happy with it now!
ekhalil
Mar 31, 2019Master
- Does your Internet connection require any authentication?
- Try using the MAC address of the Ariss router in Orbi internet settings, you can find this seetting in the web GUI under >> ADVANCED >> Setup >> Internet Settings >> Router MAC Address
Spiffywerks
Apr 07, 2019Guide
- FURRYe38Apr 08, 2019Guru - Experienced User
Glad that was an easy fix. Enjoy. :smileywink:
