Spiffywerks
Mar 30, 2019Guide
Orbi connected directly to FIOS ONT gets only 50% connection speed
I have an ARRIS NVG468MQ quantum gateway from Frontier FIOS with 150/150 Mbps service using the ethernet port from the ONT.
I have tried the following setups and found that if I plug the ORBI d...
- Apr 07, 2019Turns out it was a cable issue. The cable running from my ONT up to my attic was the problem. I ended up just putting the router in the garage near the ONT and the speed is now 150/150 everywhere in the house. Very happy with it now!
Spiffywerks
Apr 07, 2019Guide
Apr 08, 2019Guru - Experienced User
Glad that was an easy fix. Enjoy. :smileywink:
