ChrisChu20
Aug 12, 2021Aspirant
Orbi connecting to Anova 2.4 only
Hi, Currently trying to connect my Anova wifi to my wifi mesh setup Orbi RBR850. The Anova will only connect to 2.4ghz and will need to be the same one the phone is connected to. Is there anyway...
Aug 12, 2021Guru - Experienced User
No, you can't switch off the 5ghz. You can turn down its transmit port and disable the ssid broadcast (doesn't actually turn off the radio).
Then disable/enable the wireless on your phone. With luck it'll connect to the 2.4ghz band.
