Tendude
Sep 24, 2020Aspirant
Orbi Connecting
I had a HORRIBLE time connecting my recently purchased ORBI. QC codes did not work in the app and manual pairing attempts failed (can not detect) multiple times. After multiple attempts, the RBS50v2 ...
- Sep 24, 2020
Turn off Daisy Chaining and the satellite will connect to the router. Daisy chaining is good if you have a satellite further away in sort of a straight line. But if you are setup the way you describe, then you may be betetr off with Daisy Chaining turned off.
