Didieffe
Jun 08, 2018Aspirant
Orbi connection base to satellite
Hi everyone and sorry for my possible stupid question.
I actually connect the router and the satellite with ethernet but the location of the satellite is not really the best choice. (orange lig...
Retired_Member
Jun 08, 2018orange?
The only colors I've seen have been white, blue, or magenta (purple).
Using an ethernet cable should over ride any color display or at least the magenta (connection poor)
- DidieffeJun 08, 2018Aspirant
Ok sorry.
I would like to say Magenta; anyway the one for the poor connection.
The question is: IF I connect the base to the satellite with an ethernet, I will have better performances from the satellite than having only the wifi connection?
Thanks,
ddf
- Retired_MemberJun 08, 2018
Didieffe wrote:
Ok sorry.
Thanks,
ddf
Ethernet is always better (in most cases) than wifi.
- mith_itJun 08, 2018Luminary
It does make me wonder that he is getting a poor connection over Etherhet.
Out of curiousity did you try connecting another device to that Ethernet cable and measure the performance? Do you have problems on the Ethernet cable or is Orbi having issues?
