kwtb2488
Jul 20, 2020Aspirant
Orbi Connection Drops Once A Day
Hi I didnt see my exact model listed, its: Orbi Tri-band Whole Home Mesh WiFi System with 3Gbps Speed (RBK50) {downstairs} in addition to NETGEAR Orbi Ultra-Performance Whole Home Mesh WiFi Sat...
Jul 20, 2020Guru - Experienced User
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
kwtb2488 wrote:Hi
Orbi Tri-band Whole Home Mesh WiFi System with 3Gbps Speed (RBK50) {downstairs} in addition to NETGEAR Orbi Ultra-Performance Whole Home Mesh WiFi Satellite Extender - works with your Orbi Router to add 2,500 sq. feet at speeds up to 3 Gbps, AC3000 (RBS50) {upstairs}
Ive been having issues where my Orbi will drop connection once a day.
I have Time Warner internet but we use the Orbi System to boost for the whole house.
Always once a day, the internet drops for like 2-10 minutes. At least once a day.
Its not a huge deal but im not sure why it keeps happening.
Anyone have any things for me to look into or check out to try and fix?
Could ORBI be doing some type of update or something?
Every time it goes out, i open the Orbi app and it says internet offline and then after 2-10 minutes it comes back.
Any help is super appreciated.
Thanks!
- kwtb2488Jul 22, 2020Aspirant
I have the main Orbi router sitting right next to my Time Warner provided Modem. The Time Warner modem is ARRIS Surfboard SBG6782-AC. I have the other satellite (#1) in another room about 20-30 feet away. And then I have another satellite (#2) upstairs, pretty much directly above from where the #1 is.
- FURRYe38Jul 22, 2020Guru - Experienced User
Your modem maybe the problem. Is the wifi running on the modem? Router mode on the modem? This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
kwtb2488 wrote:I have the main Orbi router sitting right next to my Time Warner provided Modem. The Time Warner modem is ARRIS Surfboard SBG6782-AC. I have the other satellite (#1) in another room about 20-30 feet away. And then I have another satellite (#2) upstairs, pretty much directly above from where the #1 is.
