kwtb2488
Jul 20, 2020Aspirant
Orbi Connection Drops Once A Day
Hi I didnt see my exact model listed, its: Orbi Tri-band Whole Home Mesh WiFi System with 3Gbps Speed (RBK50) {downstairs} in addition to NETGEAR Orbi Ultra-Performance Whole Home Mesh WiFi Sat...
kwtb2488
Jul 22, 2020Aspirant
I have the main Orbi router sitting right next to my Time Warner provided Modem. The Time Warner modem is ARRIS Surfboard SBG6782-AC. I have the other satellite (#1) in another room about 20-30 feet away. And then I have another satellite (#2) upstairs, pretty much directly above from where the #1 is.
Jul 22, 2020Guru - Experienced User
Your modem maybe the problem. Is the wifi running on the modem? Router mode on the modem? This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
kwtb2488 wrote:I have the main Orbi router sitting right next to my Time Warner provided Modem. The Time Warner modem is ARRIS Surfboard SBG6782-AC. I have the other satellite (#1) in another room about 20-30 feet away. And then I have another satellite (#2) upstairs, pretty much directly above from where the #1 is.
