CB01
Aug 20, 2019Tutor
Orbi connection inconsistent speed
I have 3 Orbi RBR50 setup in my house. I am seeing issues with anyone connected to the satellite units seeing inconsistent speeds. So I plugged a laptop into the main unit and one into the first sa...
Aug 20, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
