CB01
Aug 20, 2019Tutor
Orbi connection inconsistent speed
I have 3 Orbi RBR50 setup in my house. I am seeing issues with anyone connected to the satellite units seeing inconsistent speeds. So I plugged a laptop into the main unit and one into the first sa...
CB01
Aug 20, 2019Tutor
Home is around 3800 sq ft on two floors. I have the main unit RBR50 and RBS50 that I was testing both on the main floor. I would say they are 50ft plus between them. Is 30ft the min or max suggested distance between? The 3rd unit is an RBS50 is upstairs and is located between the other two. The network map on the app shows both RBS connecting to the RBR50. I will try putting them all on the same floor and see if that helps.
2.4GHz is set to Auto
5GHz is set to 48
2 Neighbors have WiFi, but my signal strength is much higher.
Beamforming and MIMO are both enabled already.
I will check other settings are as mentioned after I try moving the units around.
There are new units. Initial configuration pulled down this firmware version. No reset was done afterwards. Should it be?
CB01
Aug 20, 2019Tutor
Didn't mention it, but I am using Spectrum as service provider. But I am seeing issues with pinging two units that are hardwired into Orbi boxes.
Spectrum Cable Modem is Hitron E31N2v1. It does not have WiFi enabled.
