CB01
Aug 20, 2019Tutor
Orbi connection inconsistent speed
I have 3 Orbi RBR50 setup in my house. I am seeing issues with anyone connected to the satellite units seeing inconsistent speeds. So I plugged a laptop into the main unit and one into the first sa...
Retired_Member
Aug 20, 2019
CB01 wrote:I am running Firmware v2.3.5.30.
What were your 'speeds' BEFORE v2.3.5.30. ??
- CB01Aug 20, 2019Tutor
I had never used it with any older firmware. This is a new setup.
- CB01Aug 21, 2019Tutor
I tried enabling the first list and disabling the second set. No real performance change. The wired connection on the satellite is still terrible. The app says the backhaul connection is good between the router and the satellite, but the ping time is still all over the place. It will be good for a few pings and then jump to 500ms. It just doesn't work. I can attempt a factory reset and rebuild, but any other suggestions prior to returning the units and trying another product?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- FURRYe38Aug 21, 2019Guru - Experienced User
Are these pings with the RBR or at the RBS?
Please try a factory reset and test again with out the RBS connected...
