tomcat81
Apr 13, 2018Tutor
Orbi connection status is offline
Just switched modems and when I connect the Orbi up it says my internet is offline.
- Apr 25, 2018
Ok, this is a gateway modem/router.
A few configurations when using this kind of modem:
1. Fully bridge the ISP Modem.
2. If the modem can't be bridged fully, input the IP address that the Orbi router gets from the ISP modem, in to the modems DMZ keeping the Orbi router in router mode.
3. Keep the modem in router mode and configure the Orbi router in AP mode.
tomcat81 wrote:
It is an ARRIS BGW210
guzzijason
Apr 13, 2018Apprentice
Does the new modem work if you bypass the Orbi and just connect to it directly?
- tomcat81Apr 17, 2018Tutor
yes it does
