tomcat81's avatar
Apr 13, 2018
Orbi connection status is offline
Just switched modems and when I connect the Orbi up it says my internet is offline.
  • FURRYe38's avatar
    Ok, this is a gateway modem/router.
    A few configurations when using this kind of modem:
    1. Fully bridge the ISP Modem.
    2. If the modem can't be bridged fully, input the IP address that the Orbi router gets from the ISP modem, in to the modems DMZ keeping the Orbi router in router mode.
    3. Keep the modem in router mode and configure the Orbi router in AP mode.
    tomcat81 wrote:
    It is an ARRIS BGW210
