For modems with build in router and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Good Luck.
","body@stringLength":"2455","rawBody":"https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
https://www.netgear.com/orbi/default.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems
https://kb.netgear.com/31097/How-many-devices-can-my-Orbi-system-support
Couple of options,
Good Luck.
","kudosSumWeight":0,"repliesCount":0,"postTime":"2021-02-23T13:44:13.108-08:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:2061323_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":471},"read":false,"visibilityScope":"PUBLIC","isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}},"canReply":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","key":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","args":[]}},"canAcceptSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","args":[]}},"canRejectSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","args":[]}},"canTag":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","key":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","args":[]}},"canEdit":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","key":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","args":[]}},"canKudo":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","key":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","args":[]}}},"customFields":[],"replies":{"__typename":"MessageConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:theme:customTheme1-1759225537395":{"__typename":"CachedAsset","id":"theme:customTheme1-1759225537395","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"10px","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"Browser_Icon-1697787492229.PNG.png","imageLastModified":"1697787496004","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"NETGEAR_Community-1744420932835.png","imageLastModified":"1744420934427","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1600px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"3px","borderRadius":"3px","borderRadiusLg":"5px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"700","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-gray-900)","secondaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-200)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"DARK","sideContent":"DARK","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.06)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#2D242D","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#148563","blogColor":"#1CBAA0","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#4C6B90","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#333333","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#000000","secondary":"#333333","bodyText":"#504B51","bodyBg":"#EFF4F9","info":"#409AE2","success":"#41C5AE","warning":"#FCC844","danger":"#D13A1F","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#FFFFFF","#EFF4F9","#00B9FF","#6C717A","#26E880","#002FFF","#2F353F","#12171E","#085E4F","#001D9E","#986943"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Outfit ExtraLight","fontStyle":"NORMAL","fontWeight":"600","h1FontSize":"40px","h2FontSize":"36px","h3FontSize":"32px","h4FontSize":"28px","h5FontSize":"24px","h6FontSize":"22px","lineHeight":"1.3","subHeaderFontSize":"14px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":null,"imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"12px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"2px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"12px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"2px","tableBgColor":"transparent","tableBorderColor":"var(--lia-bs-gray-700)","tableBorderStyle":"solid","tableCellPaddingX":"5px","tableCellPaddingY":"5px","tableTextColor":"var(--lia-bs-body-color)","tableVerticalAlign":"middle","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Outfit","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1","fontSizeBase":"17px","fontSizeXxs":"11px","fontSizeXs":"15px","fontSizeSm":"16px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Nunito Regular","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["NunitoRegular-normal-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Nunito Italic","styles":[{"style":"ITALIC","weight":"400","__typename":"FontStyleData"}],"assetNames":["NunitoItalic-italic-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Nunito Sans","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["NunitoSans-normal-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Outfit","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"}],"assetNames":["Outfit-normal-400.woff2","Outfit-normal-700.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Outfit ExtraLight","styles":[{"style":"NORMAL","weight":"100","__typename":"FontStyleData"},{"style":"NORMAL","weight":"600","__typename":"FontStyleData"}],"assetNames":["OutfitExtraLight-normal-100.woff2","OutfitExtraLight-normal-600.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1759225536345","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:netgear.prod:pages/forums/ForumMessagePage:board:Orbi-1759225535000":{"__typename":"CachedAsset","id":"quilt:netgear.prod:pages/forums/ForumMessagePage:board:Orbi-1759225535000","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"ONE_COLUMN","bgColor":"transparent","showTitle":false,"showDescription":false,"textPosition":"CENTER","textColor":"var(--lia-bs-body-color)","sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"OneColumnQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"__typename":"OneSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1759225536345","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1759225536345","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived","section.ggPfrX.description":"","section.witfun.title":"","section.Ifupfq.description":"","section.HDsmbT.description":"","section.VzPCrA.title":"Forum Discussion","section.zhfXtQ.description":"","section.section-1744733491922.description":"","section.PcIbEX.title":"","section.oqZKRI.title":"Forum Discussion","section.LldQzr.title":"Forum Discussion","section.sEZyct.description":"","section.PcIbEX.description":"","section.Iolbog.title":"Forum Discussion","section.oPauEA.title":"","section.CzkEIE.title":"","section.lfyQfk.title":"Forum Discussion","section.fsPCXp.title":"Forum Discussion","section.jeVZXZ.title":"Forum Discussion","section.section-1744733491922.title":"","section.HDsmbT.title":"Forum Discussion","section.LldQzr.description":"","section.lfyQfk.description":"","section.mamNog.title":"","section.CdMvCb.title":"","section.sEZyct.title":"","section.CzkEIE.description":"","section.Ifupfq.title":"","section.Iolbog.description":"","section.VzPCrA.description":"","section.oqZKRI.description":"","section.section-1743419781857.description":"","section.jeVZXZ.description":"","section.szTWCQ.description":"","section.mamNog.description":"","section.oPauEA.description":"","section.IdAfoe.description":"","section.mfqezj.title":"Forum Discussion","section.section-1743419781857.title":"","section.witfun.description":"","section.szTWCQ.title":"Forum Discussion","section.fsPCXp.description":"","section.CdMvCb.description":"","section.IdAfoe.title":"","section.message-list.description":"","section.zhfXtQ.title":"","section.mfqezj.description":"","section.ggPfrX.title":"Forum Discussion"},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1759225536345","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:quiltWrapper:netgear.prod:Common:en-US-1759225535643":{"__typename":"CachedAsset","id":"quiltWrapper:netgear.prod:Common:en-US-1759225535643","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"#FFFFFF","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":true,"showRegisterLink":true,"useIconLanguagePicker":true,"showLanguagePicker":true,"useLabelLanguagePicker":true,"style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"700","controllerHighlightColor":"#4099E2","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"16px","linkBoxShadowHover":"none","backgroundOpacity":0.79,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"32px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"15px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"flex-start","linkColor":"#000000","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerHighlightTextColor":"var(--lia-yiq-dark)","controllerTextColor":"var(--lia-nav-controller-icon-color)","background":{"imageAssetName":"","color":"#FFFFFF","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"#333333","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"15px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"links":{"sideLinks":[],"mainLinks":[{"children":[{"linkType":"INTERNAL","id":"migrated-link-1","params":{"categoryId":"en-netgear-my-community"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"Common-home-networking-link","params":{"categoryId":"home-networking"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"Common-en-home-mobile-solutions-link","params":{"categoryId":"en-home-mobile-solutions"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"migrated-link-3","params":{"categoryId":"business-solutions"},"routeName":"CategoryPage"},{"linkType":"EXTERNAL","id":"migrated-link-4","url":"https://www.netgear.com/hub/","target":"BLANK"}],"linkType":"INTERNAL","id":"migrated-link-2","params":{"categoryId":"home-networking"},"routeName":"CategoryPage"},{"children":[{"linkType":"EXTERNAL","id":"migrated-link-10","url":"https://my.netgear.com/products.aspx?option=viewwarranty","target":"BLANK"},{"linkType":"EXTERNAL","id":"Common-external-link","url":"https://my.netgear.com/cases.aspx","target":"BLANK"},{"linkType":"EXTERNAL","id":"Common-external-link-2","url":"https://my.netgear.com/contracts.aspx","target":"BLANK"}],"linkType":"EXTERNAL","id":"Common-external-link-1","url":"https://my.netgear.com/home.aspx","target":"BLANK"},{"children":[{"linkType":"EXTERNAL","id":"migrated-link-12","url":"https://www.netgear.com/support/download/?model=&_ga=2.38375275.974127454.1697786862-475167439.1689166105","target":"BLANK"},{"linkType":"EXTERNAL","id":"migrated-link-9","url":"https://my.netgear.com/support/contact.aspx","target":"BLANK"}],"linkType":"EXTERNAL","id":"migrated-link-11","url":"https://www.netgear.com/support/","target":"BLANK"},{"children":[],"linkType":"EXTERNAL","id":"migrated-link-13","url":"https://www.netgear.com/search/?query=&tabOrder=.%2Findex.html%2Cblogs%2Ckhoros_conversations%2Cknowledge_articles%2Cproducts%2Csupport&facetFilters=%7B%7D&filters=%7B%7D&referrerPageUrl=https%3A%2F%2Fwww.netgear.com%2Fsupport%2F&verticalUrl=knowledge-articles.html","target":"BLANK"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-15","params":{"boardId":"en-home-orbi-app","categoryId":"home-orbi"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-16","params":{"boardId":"en-home-networking-apps","categoryId":"home-wifi-routers"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-17","params":{"boardId":"en-home-armor","categoryId":"en-home-networking-apps"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-18","params":{"boardId":"en-home-smart-parental-controls","categoryId":"en-home-networking-apps"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"Common-en-business-insight-network-management-link","params":{"boardId":"en-business-insight-network-management","categoryId":"en-business-solutions-insight"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"Common-en-home-networking-apps-link","params":{"categoryId":"en-home-networking-apps"},"routeName":"CategoryPage"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"#FFFFFF","linkHighlightColor":"#333333","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"linkTextColor":"#333333"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"transparent","visualEffects":{"showBottomBorder":true},"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-body-color)"},"__typename":"QuiltComponent"},{"id":"custom.widget.Alert_Banner","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"usePageWidth":true,"backgroundColor":"#1439FF","useBackground":false,"backgroundOpacity":1,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"var(--lia-bs-body-bg)","items":[{"id":"custom.widget.ReactNetgearFooter","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"usePageWidth":true,"backgroundColor":"#FFFFFF","useBackground":false,"backgroundOpacity":1,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:component:custom.widget.Alert_Banner-en-us-1759225629039":{"__typename":"CachedAsset","id":"component:custom.widget.Alert_Banner-en-us-1759225629039","value":{"component":{"id":"custom.widget.Alert_Banner","template":{"id":"Alert_Banner","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Banner to be used to share alerts including outages and product announcements","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Alert_Banner","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Banner to be used to share alerts including outages and product announcements","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.ReactNetgearFooter-en-us-1759225629039":{"__typename":"CachedAsset","id":"component:custom.widget.ReactNetgearFooter-en-us-1759225629039","value":{"component":{"id":"custom.widget.ReactNetgearFooter","template":{"id":"ReactNetgearFooter","markupLanguage":"REACT","style":null,"texts":{"custom-footer-aboutus-link":"https://www.netgear.com/about/","custom-footer-aboutus-text":"About Us","custom-footer-contactus-link":"https://www.netgear.com/support/contact.aspx","custom-footer-contactus-text":"Contact us","custom-footer-careers-link":"https://www.netgear.com/about/careers/","custom-footer-careers-text":"Careers","custom-footer-security-link":"https://www.netgear.com/security/","custom-footer-security-text":"Security"},"defaults":{"config":{"applicablePages":[],"description":null,"fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.ReactNetgearFooter","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":null,"fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1759225536345","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1759225536345","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"Category:category:business-solutions":{"__typename":"Category","id":"category:business-solutions","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:en-netgear-my-community":{"__typename":"Category","id":"category:en-netgear-my-community","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-home-networking-apps":{"__typename":"Forum","id":"board:en-home-networking-apps","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:en-home-networking-apps":{"__typename":"Category","id":"category:en-home-networking-apps","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-home-armor":{"__typename":"Forum","id":"board:en-home-armor","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-home-orbi-app":{"__typename":"Forum","id":"board:en-home-orbi-app","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-business-insight-network-management":{"__typename":"Forum","id":"board:en-business-insight-network-management","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-home-smart-parental-controls":{"__typename":"Forum","id":"board:en-home-smart-parental-controls","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:en-home-mobile-solutions":{"__typename":"Category","id":"category:en-home-mobile-solutions","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"CachedAsset:text:en_US-components/community/Navbar-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1759225536345","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","Common_GxOGBp-italian-link":"COMUNITÀ","Common_StQtwX-external-link-7":"Unterstützung nach Produkt","Common_StQtwX-external-link-6":"Downloads","Common_StQtwX-external-link-5":" UNTERSTÜTZUNG","Common_GxOGBp-cable-modems-routers-link":"Modem DSL & Router","Common-business-solutions-link":"NETGEAR For Business","Common_StQtwX-de-netgear-my-community-link":"Meine Gemeinschaft","Common_StQtwX_SXNPsj-wifi-7-link":"Common_SXNPsj-wifi-7-link","Common-external-link-6":"NETGEAR Blog","Common-external-link-5":"Support by product","Common-external-link-4":"Warranty Information","Common-external-link-3":"SEARCH KNOWLEDGE BASE","Common_GxOGBp-external-link-3":" I miei casi","Common_StQtwX-external-link-4":"WISSENSBASIS","Common-en-home-orbi-be-link-1":"Orbi WiFi 7 (BE) Mesh Systems","Common_StQtwX-external-link-3":"Meine Fälle","Common_GxOGBp-external-link-4":"Supporto per prodotto","Common_GxOGBp-external-link":" IL MIO NETGEAR","Common_StQtwX-external-link-2":"Meine Abonnements","Common_GxOGBp-external-link-5":"SUPPORTO","Common_StQtwX-external-link-1":"Meine registrierten Produkte","Common_GxOGBp-external-link-6":"Informazioni sulla garanzia","Common_GxOGBp-external-link-7":"Download","Common_GxOGBp-external-link-8":"BASE DI CONOSCENZA","Common-home-networking-link":"Home Solutions","Common_StQtwX-de-heimnetzwerk-link":"Home-Lösungen","Common_WNjGdS_GxOGBp-it-home-mobile-solutions-link":"Redes de Negocio","Common_GxOGBp-external-link-1":" I miei prodotti registrati","Common_GxOGBp-3":"SUPPORTO","Common_GxOGBp-2":" LA COMUNITÀ","Common_GxOGBp-external-link-2":" I miei abbonamenti","Common-external-link-2":"My Contracts","Common-external-link-1":"MY NETGEAR","Common_GxOGBp-it-home-mobile-solutions-link":"Soluzioni mobili","Common_WNjGdS_GxOGBp-1":" MI NETGEAR","Common_WNjGdS_GxOGBp-0":"DESCARGAS","Common_WNjGdS_GxOGBp-3":"APOYO","Common_WNjGdS_GxOGBp-2":"COMUNIDAD","Common_GxOGBp-1":" IL MIO NETGEAR","Common_SXNPsj-external-link":"MON NETGEAR","Common_GxOGBp-0":" SCARICA","Common_SXNPsj-wifi-7-link":"Communauté","Common_StQtwX-de-business-losungen-link":"Business Lösungen","Common-mobile-wifi-link-1":"Mobile WiFi","Common_StQtwX-de-home-mobile-wifi-link":"Mobile Lösungen","Common-external-link":"My Cases","Common_SXNPsj-wifi-7-routers-link":"Nighthawk WiFi 7 Routers","Common-en-home-orbi-app-link":"Orbi App","migrated-link-18":"NETGEAR Smart Parental Controls","Common-en-home-orbi-be-link":"Orbi WiFi 7 (BE) Mesh Systems","migrated-link-16":"Nighthawk App","migrated-link-17":"NETGEAR Armor","migrated-link-14":"Armor & Parental Controls","migrated-link-15":"Orbi App","migrated-link-12":"Firmware Downloads","migrated-link-13":"KNOWLEDGE BASE","Common-en-home-netgear-armor-link":"NETGEAR Armor, powered by Bitdefender","Common-en-home-networking-apps-link":"NETGEAR APPS","Common_WNjGdS_GxOGBp-external-link":"Registro de mi producto","Common_WNjGdS_GxOGBp-wifi-7-routers-link":"Soluzioni Business","Common_GxOGBp-it-business-soluzioni-link":"Soluzioni Business","migrated-link-10":"My Registered Products","Common_SXNPsj-fr-entreprises-solutions-link":"Solutions Business","migrated-link-11":"SUPPORT","Common_SXNPsj-external-link-2":"My Cases","Common_SXNPsj-external-link-1":"Mes produits enregistrés","Common-home-wifi-link":"Home WiFi","Common_GxOGBp-wifi-7-link":"Rete domestica","Common-en-home-smart-parental-controls-link":"NETGEAR Smart Home Parental Controls","migrated-link-9":"Contact Us","Common_GxOGBp-de-netgear-my-community-link":"Meine Gemeinschaft","migrated-link-7":"Common-external-link-1","migrated-link-8":"Common-external-link-2","Common_StQtwX-external-link":"MEIN NETGEAR","migrated-link-1":"My Community","migrated-link-2":"COMMUNITY","migrated-link-0":"Firmware Downloads","migrated-link-5":"migrated-link-1","migrated-link-6":"Common-external-link","migrated-link-3":"Business Solutions","migrated-link-4":"NETGEAR Blog","Common_GxOGBp-wifi-7-routers-link":"Soluzioni Business","Common_SXNPsj-fr-domestique-reseau-link":"Solutions Pour La Maison","Common_WNjGdS_GxOGBp-wifi-7-link":"Redes de Hogar","Common_SXNPsj-cable-modems-routers-link":"Modems and Modem Gateways","Common_SXNPsj-fr-home-mobile-solutions-link":"Solutions Mobiles","Common_LXGzNf_ZDApqi_SXNPsj-wifi-7-link":"Common_SXNPsj-wifi-7-link","Common_StQtwX_SXNPsj-2":" GEMEINSCHAFT","Common_SXNPsj-3":"SUPPORT","Common-en-home-networking-apps-link-1":"Nighthawk App","Common_SXNPsj-1":"MY NETGEAR","Common_SXNPsj-bienvenue-link":"Ma Communauté","Common_SXNPsj-2":"NETGEAR Forum","Common-cable-modems-routers-link":"Modems and Modem Gateways","Common_WNjGdS_GxOGBp-external-link-3":"BASE DE CONOCIMIENTOS","Common_WNjGdS_GxOGBp-external-link-2":" Mis Casos","Common_WNjGdS_GxOGBp-external-link-1":"Mis Suscripciones","Common-en-netgear-my-community-link":"My Community","Common-digital-canvas-link":"Digital Canvas","Common-wifi-7-routers-link":"Nighthawk WiFi 7 Routers","Common-en-business-insight-network-management-link":"Insight","Common_GxOGBp-it-home-networking-link":"Soluzioni per la casa","Common-wifi-7-link":"Orbi WiFi 7 Mesh Systems","Common-wired-networking-link":"Wired Networking for Home","Common_LXGzNf_ZDApqi_SXNPsj-2":"NETGEAR Forum","Common-mobile-wifi-link":"Mobile WiFi","Common-en-home-mobile-solutions-link":"Mobile Solutions"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1759225536345","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1759225536345","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1759225536345","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/languages/UseLanguageText-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/languages/UseLanguageText-1759225536345","value":{"language.browserLanguage.label":"Browser Default","language.ar-AE.label":"Arabic","language.bg-BG.label":"Bulgarian","language.ca-AD.label":"Catalan","language.cs-CZ.label":"Czech","language.da-DK.label":"Danish","language.de-DE.label":"German","language.el-GR.label":"Greek","language.en-GB.label":"English (UK)","language.en-US.label":"English (US)","language.es-ES.label":"Spanish","language.es-MX.label":"Spanish (Mexican)","language.et-EE.label":"Estonian","language.fa-IR.label":"Persian (Farsi)","language.fi-FI.label":"Finnish","language.fr-FR.label":"French","language.he-IL.label":"Hebrew (modern)","language.hr-HR.label":"Croatian","language.hu-HU.label":"Hungarian","language.in-ID.label":"Indonesian","language.it-IT.label":"Italian","language.ja-JP.label":"Japanese","language.ko-KR.label":"Korean","language.lt-LT.label":"Lithuanian","language.lv-LV.label":"Latvian","language.ms-MY.label":"Malay","language.nl-NL.label":"Dutch","language.no-NO.label":"Norwegian","language.pl-PL.label":"Polish","language.pt-BR.label":"Portuguese (Brazilian)","language.pt-PT.label":"Portuguese","language.ro-RO.label":"Romanian","language.ru-RU.label":"Russian","language.sk-SK.label":"Slovak","language.sq-AL.label":"Albanian","language.sv-SE.label":"Swedish","language.th-TH.label":"Thai","language.tr-TR.label":"Turkish","language.uk-UA.label":"Ukrainian","language.vi-VN.label":"Vietnamese","language.zh-CN.label":"Chinese (Simplified)","language.zh-TW.label":"Chinese (Traditional)","timezone.fieldLabel.label":"Time Zone","timezone.delimiter.label":"------------------------------","timezone.Etc-GMT+12.label":"GMT -12:00 Dateline","timezone.Pacific-Samoa.label":"GMT -11:00 Samoa","timezone.US-Hawaii.label":"GMT -10:00 U.S. Hawaiian Time","timezone.US-Aleutian.label":"GMT -10:00 Aleutian Islands","timezone.Pacific-Marquesas.label":"GMT -09:30 Marquesas","timezone.Pacific-Gambier.label":"GMT -09:00 Gambier Islands","timezone.US-Alaska.label":"GMT -09:00 U.S. Alaska Time","timezone.US-Pacific.label":"GMT -08:00 U.S. Pacific Time","timezone.Pacific-Pitcairn.label":"GMT -08:00 Pitcairn Islands","timezone.US-Mountain.label":"GMT -07:00 U.S. Mountain Time","timezone.US-Arizona.label":"GMT -07:00 U.S. Mountain Time (Arizona)","timezone.US-Central.label":"GMT -06:00 U.S. Central Time","timezone.Mexico-General.label":"GMT -06:00 Mexico","timezone.America-Costa_Rica.label":"GMT -06:00 Costa Rica","timezone.US-Eastern.label":"GMT -05:00 U.S. Eastern Time","timezone.America-Bogota.label":"GMT -05:00 Colombia, Peru, South America","timezone.Canada-Atlantic.label":"GMT -04:00 Atlantic Time","timezone.America-Puerto_Rico.label":"GMT -04:00 Puerto Rico","timezone.Canada-Newfoundland.label":"GMT -03:30 Newfoundland, Canada","timezone.America-Buenos_Aires.label":"GMT -03:00 Argentina","timezone.Brazil-East.label":"GMT -03:00 Brazil","timezone.Atlantic-South_Georgia.label":"GMT -02:00 Mid-Atlantic","timezone.Atlantic-Cape_Verde.label":"GMT -01:00 Cape Verde","timezone.Atlantic-Azores.label":"GMT -01:00 Azores","timezone.Europe-London.label":"GMT ------ U.K.","timezone.Iceland.label":"GMT ------ Iceland","timezone.Europe-Madrid.label":"GMT +01:00 Spain","timezone.Africa-Algiers.label":"GMT +01:00 Algiers, Africa","timezone.Europe-Amsterdam.label":"GMT +01:00 Central Europe","timezone.Europe-Athens.label":"GMT +02:00 Eastern Europe","timezone.Africa-Tripoli.label":"GMT +02:00 Tripoli, Africa","timezone.Egypt.label":"GMT +02:00 Egypt","timezone.Israel.label":"GMT +02:00 Israel","timezone.Asia-Riyadh.label":"GMT +03:00 Saudi Arabia","timezone.Iran.label":"GMT +03:30 Iran","timezone.Europe-Moscow.label":"GMT +03:00 Russia","timezone.Europe-Samara.label":"GMT +04:00 Samara, Europe","timezone.Asia-Dubai.label":"GMT +04:00 Arabian","timezone.Asia-Kabul.label":"GMT +04:30 Afghanistan","timezone.Asia-Karachi.label":"GMT +05:00 Pakistan, West Asia","timezone.Asia-Yekaterinburg.label":"GMT +05:00 Yekaterinburg, Asia","timezone.Asia-Calcutta.label":"GMT +05:30 India","timezone.Asia-Thimphu.label":"GMT +06:00 Bangladesh, Central Asia","timezone.Asia-Novosibirsk.label":"GMT +06:00 Novosibirsk, Asia","timezone.Asia-Rangoon.label":"GMT +06:30 Burma","timezone.Asia-Bangkok.label":"GMT +07:00 Bangkok, Hanoi, Jakarta","timezone.Asia-Krasnoyarsk.label":"GMT +07:00 Krasnoyarsk, Asia","timezone.PRC.label":"GMT +08:00 China","timezone.Singapore.label":"GMT +08:00 Singapore","timezone.Asia-Taipei.label":"GMT +08:00 Taiwan","timezone.Australia-West.label":"GMT +08:00 Australia (WT)","timezone.Asia-Irkutsk.label":"GMT +08:00 Irkutsk, Asia","timezone.Japan.label":"GMT +09:00 Japan","timezone.Asia-Seoul.label":"GMT +09:00 Korea","timezone.Asia-Yakutsk.label":"GMT +09:00 Yakutsk, Russia","timezone.Australia-North.label":"GMT +09:30 Australia (NT)","timezone.Australia-Adelaide.label":"GMT +09:30 Australia (ST)","timezone.Australia-Sydney.label":"GMT +10:00 Australia (ET)","timezone.Australia-Queensland.label":"GMT +10:00 Australia (Queensland)","timezone.Asia-Magadan.label":"GMT +10:00 Magadan, Asia","timezone.Australia-Lord_Howe.label":"GMT +10:30 Australia (Lord Howe)","timezone.Pacific-Guadalcanal.label":"GMT +11:00 Central Pacific","timezone.Pacific-Norfolk.label":"GMT +11:30 Norfolk Islands","timezone.Pacific-Auckland.label":"GMT +12:00 New Zealand","timezone.Pacific-Fiji.label":"GMT +12:00 Fiji","timezone.Antarctica-South_Pole.label":"GMT +12:00 South Pole, Antarctica"},"localOverride":false},"CachedAsset:text:en_US-components/languages/LanguagePicker-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/languages/LanguagePicker-1759225536345","value":{"dropdown.title":"Language selector","selected.language":"Currently selected language","toast.successMessage":"Go to the {newLanguage} community
