bobglenn67
Oct 27, 2020Follower
Orbi connection to cell phone
I live in a remote mountain area and use Viasat as my internet connection. Not good and expensive.What Orbi hardware do I need to connect to an iPhone 11 using AT&T as a provider?
Oct 27, 2020Guru - Experienced User
First off, does your ISP provide you with a modem that has a built in router? If so, This would be a double NAT (two router) condition which isn't recommended if you choose to install a Orbi system. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
You can review the Orbi LTE system if you wan to use a cell service provider for your connection:
https://community.netgear.com/t5/Orbi-LTE/bd-p/en-home-orbi-lte
