Proton68
Feb 13, 2019Aspirant
Orbi connection to China
Hi,
I've upgraded my IPS system and it has begun to send me alerts notifying that my orbi device was connecting on port 80 to an address that seems to be in China, and it does so regularly. doe...
ekhalil
Feb 14, 2019Master
Proton68 wrote:
Hi,
I've upgraded my IPS system and it has begun to send me alerts notifying that my orbi device was connecting on port 80 to an address that seems to be in China, and it does so regularly. does anyone know why it does that ?
best regards
Message: IPS Alert 1: A Network Trojan was Detected. Signature ET MALWARE Suspicious User-Agent (1 space). From: 10.1.1.16:52320, to: 203.205.142.208:80, protocol: TCP
Message: IPS Alert 1: A Network Trojan was Detected. Signature ET MALWARE Suspicious User-Agent (1 space). From: 10.1.1.16:52230, to: 203.205.255.80:8080, protocol: TCP
When you use the Orbi app and you login to your Netgear account, the app creates a VPN connection from your Netgear account on the cloud to Orbi to be able to manage your Orbi from the app. I think this is what your IPS sees.
This is only needed when using the app for Orbi management but not when you use the web GUI.
CrimpOn
Feb 14, 2019Guru - Experienced User
The WhoIs lookup on these IP's traces back to:
inetnum: 203.205.192.0 - 203.205.255.255 netname: TENCENT-NET-AP descr: Shenzhen Tencent Computer Systems Company Limited descr: Tencent Building, Kejizhongyi Avenue,Hi-techPark, descr: NanshanDistrict, Shenzhen country: CN
inetnum: 203.205.128.0 - 203.205.159.255 netname: TENCENT-NET-AP descr: Shenzhen Tencent Computer Systems Company Limited descr: Tencent Building, Kejizhongyi Avenue,Hi-techPark, descr: NanshanDistrict, Shenzhen country: CN
This doesn't smell like "Netgear" to me. If 10.1.1.16 is the Orbi's WAN port, you could use the debug page to capture the LAN traffic and see exactly which device on your Orbi is connecting to those IP's.
- michaelkenwardFeb 14, 2019Guru - Experienced User
See above.
Nor does it smell like the Chinese or Russian governments.
Many of these things tracks back to something else on the local network. Sometimes an IoT device. Who knows?
Don't immediately think Chinese IP address = nasty. Look under the hood for what is really going on.
This is the important bit:
...capture the LAN traffic and see exactly which device on your Orbi is connecting to those IP's.The router's log may be helpful. But it also had a habit for finding useless and misleading information.
But first check the plumbing.
- Chuck_MFeb 14, 2019Mentor
You would figure Netgear armor would ID and take care of this :) LOL!
- CrimpOnFeb 14, 2019Guru - Experienced User
I had not realized that Netgear Armor was available for the Orbi product line. Everything I have seen mentions the Nighthawk line.
With our houses filling up with devices that can be controlled using smartphone apps, pretty soon we'll have dozens of open ports. In my case, nearly everything connects back to Amazon Web Services (AWS).
It would be fascinating to know which Internet Protection System you have and how it fits into the modem->router environment.
- Proton68Feb 14, 2019Aspirant
thanks for the suggestion, will try to do that ! :-)
- JoeCymruFeb 15, 2019Virtuoso
Personally I would be concerned and not about Orbi. Tencent is the largest social gaming company on earth and also has an instant messaging service. Port 80 traffic to tencent could be worm or trojan utilizing one of your devices to try to hook up for fraudulent purposes.
- CrimpOnFeb 15, 2019Guru - Experienced User
Once the connection is traced to a specific device, the next step may be to determine which app on that device is opening the connection.
- michaelkenwardFeb 15, 2019Guru - Experienced User
To help to home in on this excellent suggestion, in the past there have been references to devices like IoT cameras and other cloud connected widgets. They make a lot of those in China!
