Proton68
Feb 13, 2019Aspirant
Orbi connection to China
Hi,
I've upgraded my IPS system and it has begun to send me alerts notifying that my orbi device was connecting on port 80 to an address that seems to be in China, and it does so regularly. doe...
CrimpOn
Feb 14, 2019Guru - Experienced User
The WhoIs lookup on these IP's traces back to:
inetnum: 203.205.192.0 - 203.205.255.255 netname: TENCENT-NET-AP descr: Shenzhen Tencent Computer Systems Company Limited descr: Tencent Building, Kejizhongyi Avenue,Hi-techPark, descr: NanshanDistrict, Shenzhen country: CN
inetnum: 203.205.128.0 - 203.205.159.255 netname: TENCENT-NET-AP descr: Shenzhen Tencent Computer Systems Company Limited descr: Tencent Building, Kejizhongyi Avenue,Hi-techPark, descr: NanshanDistrict, Shenzhen country: CN
This doesn't smell like "Netgear" to me. If 10.1.1.16 is the Orbi's WAN port, you could use the debug page to capture the LAN traffic and see exactly which device on your Orbi is connecting to those IP's.
michaelkenward
See above.
Nor does it smell like the Chinese or Russian governments.
Many of these things tracks back to something else on the local network. Sometimes an IoT device. Who knows?
Don't immediately think Chinese IP address = nasty. Look under the hood for what is really going on.
This is the important bit:
...capture the LAN traffic and see exactly which device on your Orbi is connecting to those IP's.
The router's log may be helpful. But it also had a habit for finding useless and misleading information.
But first check the plumbing.
- Chuck_MFeb 14, 2019Mentor
You would figure Netgear armor would ID and take care of this :) LOL!
- CrimpOnFeb 14, 2019Guru - Experienced User
I had not realized that Netgear Armor was available for the Orbi product line. Everything I have seen mentions the Nighthawk line.
With our houses filling up with devices that can be controlled using smartphone apps, pretty soon we'll have dozens of open ports. In my case, nearly everything connects back to Amazon Web Services (AWS).
It would be fascinating to know which Internet Protection System you have and how it fits into the modem->router environment.
